Publication date: 02/06/2025
Summary of Control Chart Types
The most common control charts are available in Control Chart Builder and in the platforms in the Analyze > Quality and Process > Control Chart menu. Use Control Chart Builder as your first choice to easily and quickly generate charts. JMP automatically chooses the appropriate chart type based on the data. Table 3.3 through Table 3.7 summarize the different control chart types.
Table 3.3 Variable Charts Without Grouping Variable or Nonsummarized Data
Chart Types
Control Chart Builder Options
Points > Statistic
Limits > Sigma
Individual
Individual
Moving Range
Moving Range on Individual
Moving Range
Moving Range
Individual (limits computed on median moving range)
Individual
Median Moving Range
Median Moving Range on Individual
Moving Range
Median Moving Range
Run Chart
Individual
Levey Jennings
Individual
Levey Jennings
Table 3.4 Variable Charts with Grouping Variables or Summarized Data
Chart Types
Points > Statistic
Limits > Sigma
XBar (limits computed on range)
Average
Range
XBar (limits computed on standard deviation)
Average
Standard Deviation
R
Range
Range
S
Standard Deviation
Standard Deviation
Levey Jennings
Average
Levey Jennings or overall Standard Deviation
Table 3.5 Presummarize Charts
Chart Types
Points > Statistic
Limits > Sigma
Individual on Group Means
Average
Moving Range
Individual on Group Means (limits computed on median moving range)
Average
Median Moving Range
Individual on Group Std Devs
Standard Deviation
Moving Range
Individual on Group Std Devs (limits computed on median moving range)
Standard Deviation
Median Moving Range
Moving Range on Group Means
Moving Range on Means
Moving Range
Median Moving Range on Group Means
Median Moving Range
Moving Range on Group Std Devs
Moving Range on Std Dev
Moving Range
Median Moving Range on Group Std Devs
Median Moving Range
Table 3.6 Attribute Charts
Chart Types
Points > Statistic
Limits > Sigma
P chart
Proportion
Binomial
NP chart
Count
Binomial
C chart
Count
Poisson
U chart
Proportion
Poisson
Laney P chart
Proportion
Binomial adjusted by a moving range sigma value
Laney U chart
Proportion
Poisson adjusted by a moving range sigma value
Table 3.7 Short Run Charts
Chart Types
Points > Statistic
Limits > Sigma
Short Run Difference
Centered
Moving Range
Short Run Z
Standardized
Moving Range
Short Run Moving Range on Centered
Moving Range Centered
Moving Range
Short Run Moving Range on Standardized
Moving Range Standardized
Moving Range
