Quality and Process Methods > Control Chart Builder
Publication date: 02/06/2025
Create Control Charts Interactively
Use Control Chart Builder to create control charts of your process data. Control Chart Builder can be launched as an interactive workspace or from specific control chart menu options. In the interactive workspace, you select the variables that you want to chart and drag them into zones. JMP automatically chooses an appropriate chart type based on the data. You can quickly create another type of chart, or change the current settings for an existing chart.
A control chart is a graphical and analytic tool for monitoring process variation. The natural variation in a process can be quantified using a set of control limits. Control limits help distinguish common-cause variation from special-cause variation. Typically, action is taken to identify and eliminate special-cause variation. It is also important to quantify the common-cause variation in a process, as this determines the capability of a process.
Figure 3.1 Control Chart Builder Example
Contents
Overview of Control Chart Builder
Example of Control Chart Builder
Control Chart Types
Shewhart Control Charts for Variables
Shewhart Control Charts for Attributes
Short Run Control Charts
Rare Event Control Charts
Summary of Control Chart Types
Launch Control Chart Builder
Control Chart Builder Interactive Workspace
Launch Windows for Specific Control Charts
Control Chart Builder Window
Control Chart Builder Options
Control Chart Builder Red Triangle Menu Options
Options Panel and Right-Click Chart Options
Control Chart Builder Right-Click Axis Options
Control Limits in Control Chart Builder
Excluded and Hidden Samples in Control Chart Builder
Additional Examples of Control Chart Builder
Example of Control Limits
Example of Individual Measurement and Moving Range Charts
Example of an XBar and R Chart
Example of XBar and R Charts with Varying Subgroup Sizes
Example of a Short Run Control Chart
Example of a Run Chart
Example of a P Chart
Example of a Laney P′ Chart
Example of an NP Chart
Example of a C Chart
Example of a U Chart
Example of a G Chart
Example of a T Chart
Example of a Three Way Control Chart
Example of Multiple Control Charts
Statistical Details for Control Chart Builder
Statistical Details for XBar and R Charts
Statistical Details for XBar and S Charts
Statistical Details for Individual Measurement and Moving Range Charts
Statistical Details for P, NP, and Laney P′ Charts
Statistical Details for U, C, and Laney U′ Charts
Statistical Details for Levey-Jennings Charts
Statistical Details for Short Run Control Charts
Statistical Details for G Charts
Statistical Details for T Charts
Statistical Details for Three Way Control Charts
