Publication date: 02/06/2025
Statistical Details for Three Way Control Charts
This section describes how the sigma values are calculated for Three Way control charts in Control Chart Builder.
Within Sigma Based on Average of Ranges
The within sigma estimate for three way control charts that is estimated using the average of ranges can be used for the Individual on Means, Moving Range on Means and R chart.
Equation shown here
The formula uses the following notation:
Ri = range of ith subgroup
ni = sample size of ith subgroup
d2(ni) = expected value of the range of ni independent normally distributed variables with unit standard deviation
N = number of subgroups for which ni ≥ 2
Within Sigma Based on Average of Unbiased Standard Deviations
The within sigma estimate for three way control charts that is estimated using the average of unbiased standard deviations can be used for the Individual on Means, Moving Range on Means, and S chart.
Equation shown here
si = sample standard deviation of the ith subgroup
c4(ni) = expected value of the standard deviation of ni independent normally distributed variables with unit standard deviation
Between Sigma
The between sigma estimate for three way control charts is estimated using the moving range of subgroup means.
Equation shown here
Equation shown here = the mean of the nonmissing moving ranges computed as (MR2+MR3+...+MRN)/(N-1) where MRi = |yi - yi-1|.
d2(2) = expected value of the range of two independent normally distributed variables with unit standard deviation.
Equation shown here, the harmonic mean of subgroup sample sizes.
Note: If between Sigma is estimated as a negative value, it is set to 0.
Between-and-Within Sigma
The between-and-within sigma estimate for three way control charts is estimated using a combination of the within sigma and between sigma estimates.
Equation shown here
