Quality and Process Methods
Publication date: 02/06/2025
Introduction to Quality and Process Methods
Tools for Process and Product Improvement
Quality and Process Methods describes a number of methods and tools that are available in JMP to help you evaluate and improve quality and process performance:
Control charts provide feedback on key variables and show when a process is in, or out of, statistical control. “Control Chart Builder” describes the JMP approach to creating control charts using an interactive control chart platform called Control Chart Builder.
The Measurement Systems Analysis platform assesses the precision, consistency, and bias of a system. Before you can study a process, you need to make sure that you can accurately and precisely measure the process. If variation comes from the measurement itself, then you are not reliably learning about the process. Use this analysis to find out how your system is performing. See “Measurement Systems Analysis”.
The Type 1 Gauge platform assesses whether a measurement system, or gauge, is repeatable. Specifically, the analysis determines whether a measurement system can repeatedly measure a part and obtain measurements that are close to a known reference standard. See “Type 1 Gauge Analysis”.
The Variability/Attribute Gauge Chart platform creates variability or attribute gauge charts. Variability charts analyze continuous measurements and reveal how your system is performing. Attribute charts analyze categorical measurements and show you measures of agreement across responses. You can also perform a gauge study to see measures of variation in your data. See “Variability Gauge Charts” and “Attribute Gauge Charts”.
The Process Screening platform enables you to explore a large number of processes across time. The platform calculates control chart, process stability, and process capability metrics, and detects large process shifts. See “Process Screening”.
The Process Capability platform measures the ability of a process to meet specification limits. You can compare process performance, summarized by process centering and variability, to specification limits. The platform calculates capability indices based on both long-term and short-term variation. The analysis helps identify the variation relative to the specifications; this enables you to achieve increasingly higher conformance values. See “Process Capability”.
CUSUM charts enable you to make decisions based on the cumulative sum. These charts can detect small shifts in a process. See “CUSUM Control Charts”.
Exponentially weighted moving average (EWMA) charts can also be used to detect small shifts in a process. See “EWMA Control Charts”.
When you need to monitor multiple process characteristics simultaneously, see “Multivariate Control Charts”.
The Model Driven Multivariate Control Chart (MDMVCC) platform enables you to build a control chart based on principal components or partial least squares models. See “Model Driven Multivariate Control Charts”.
“Legacy Control Charts” describes the older control chart platforms in JMP. Instead of using these platforms, you are encouraged to use the Control Chart Builder platform, as well as the new CUSUM and EWMA Control Chart platforms.
The Pareto Plot platform shows the frequency of problems in a quality related process or operation. Pareto plots help you decide which problems to solve first by highlighting the frequency and severity of problems. See “Pareto Plots”.
The Diagram platform constructs cause-and-effect diagrams, which organize the sources of a problem for brainstorming or as a preliminary analysis to identify variables for further experimentation. Once complete, further analysis can be done to identify the root cause of the problem. See “Cause-and-Effect Diagrams”.
The Manage Spec Limits utility enables you to quickly add or edit many specification limits for several columns at once. See “Manage Limits”.
The Operating Characteristic (OC) Curves utility enables you to construct OC curves for control charts and attribute acceptance sampling plans. See “Operating Characteristic Curves”.
