Publication date: 02/06/2025
Window Messages
window<<Bring Window to Front
Brings the window to the front.
window<<Close Window(<nosave>)
Closes the window. If the optional argument nosave is specified, the window (journal, report, and so forth) is closed without saving or prompting.
window<<Get Content Size
Returns the size of the window’s contents.
window<<Get Window Icon
Returns the name of the window’s icon.
window<<Get Window Position
Returns the position of the window.
window<<Get Window Size
Returns the size of the window.
window<<Get Window Title
Returns the title of the window.
window<<Inval
Invalidate the display box. The window updates either when the <<Update Window message is sent or when the operating system has time for the update. See window<<Reshow for another method.
window<<Maximize Display
Maximizes the window. Deprecated.
window<<Maximize Window(Boolean)
window<<Minimize Window(Boolean)
Minimizes the window.
window<<Move Window(x, y)
Moves the window to the specified position.
window<<On Close(script)
Runs the script when the window is closed.
window<<Pad Window(Boolean)
Turns padding around a window’s contents on (1) or off (0). The default value is off.
window<<Print Window
Prints the window to the default printer. Note that the Print window is not opened and user input is not required.
window<<Reshow
Invalidates the display box and updates the window with the new content. See <<Inval and <<Update Window messages if more control over timing of the update is required.
window<<Save Window to Report(pathname, <Embed Data(Boolean)>)
Saves the current report window to a JMP report file (.jrp).
window<<Set Main Window
Sets the specified window as the default window that appears when JMP is run.
window<<Set Window Icon(icon name)
Sets the window’s icon as specified in the quoted icon name argument.
window<<Set Window Size(x, y)
Resizes the window.
window<<Show Window(Boolean)
1 shows the window (only if the window is not currently open). 0 hides the window. If the window is also minimized (on Windows) or docked (on macOS), showing the window restores it to the normal state and brings it to the front.
window<<Size Window(x, y)
Resizes the window.
window<<Update Window
Updates or refreshes the window holding the display box if there are invalidated regions. See window<<Inval and window<<Reshow for additional methods.
window<<Window Class Name
Returns the name of the window class for the display box. Valid responses include: DataTable, FormulaEditor, Starter, Journal, Launcher, Report, Dialog, DialogWithMenu, ModalDialog, FindReplace, User, Generic, ToolWindow, FindReplace, AppBuilder, and Debugger.
window<<Zoom Window
Resizes the window to be large enough to show all of its contents.
