Publication date: 02/06/2025
Type 1 Gauge Analysis Report Options
Each Type 1 Gauge Analysis report red triangle menu contains the following options:
Summary and Capability Statistics
Shows or hides the Type 1 Gauge Summary and Capability Statistics table for the corresponding response. See Summary and Capability Statistics Table.
Run Chart
Shows or hides the run chart of the measurement data for the corresponding response. See Run Chart.
Bias Test
Shows or hides the results from the bias test. This is a two-sided t test that tests the mean of the observed measurements against the reference standard.
Histogram
Shows or hides a histogram of the measurement data. This is useful for checking the normality of the measurements. The Histogram red triangle menu contains the following options:
Show Reference
Shows or hides a reference line of the reference standard value on the histogram. The reference line is shown by default.
Show Count Axis
Shows or hides a count axis to the right of the histogram frame.
