The Scatterplot Matrix window shows an ordered grouping of bivariate graphs. In each graph, you can examine the relationships between each pair of variables.
Follow the instructions in Example of a Scatterplot Matrix to produce the plot shown in Figure 6.9.
Note: For information about additional options, see Scatterplot Matrix Platform Options.
Figure 6.9 Example of a Scatterplot Matrix Window
Replace variables in the plot by dragging and dropping a variable, in one of two ways: swap existing variables by dragging and dropping a variable from one axis to the other axis; or, click a variable in the Columns panel of the associated data table and drag it onto an axis. This feature is not available for matrices in the Square format.
