Genetics > Marker Simulation > The Marker Simulation Report and Options
Publication date: 02/06/2025
The Marker Simulation report enables you to explore the expected results of crosses of the different individuals in the study.
The Marker Simulation red triangle menu contains the following options:
Show Evaluation Plot
Select this option to view the Generation Trait Evaluation Plot. These plots show how the mean trait values compare and trend across generations.
Show Diversity Plot
Select this option to view the Generation Diversity Evaluation Plots. These plots show how the measures of diversity compare and trend across generations.
Save Simulated Table
Use this option to save the simulated genotypes to a new data table.
