Genetics > Marker Simulation
Publication date: 02/06/2025
Image shown hereMarker Simulation
Marker Simulation simulates the progeny from a specified set of crosses using biallelic markers and predictor formulas (predictive models generated using the Response Screening platform) saved in your data table. This process enables you to test various crosses to estimate which crosses generate progeny with the desired combinations of traits.
Note: Specifying a large number of crosses, progeny, or both can consume considerable CPU and disk resources.
Figure 4.1 Example of the Marker Simulation Platform
The Marker Simulation platform is available only in JMP Pro.
Contents
Example of Marker Simulation
Launch the Marker Simulation Platform
Required Data Format for the Marker Simulation Platform
The Marker Simulation Report and Options
Summary of Simulation
Generation Evaluation Table
Scatterplot Matrix
Generation Trait Evaluation Plot
Generation Diversity Evaluation Plots
