Quality and Process Methods > Process Capability > Statistical Details for the Process Capability Platform > Statistical Details for the Parameterizations of Distributions
Publication date: 02/06/2025
This section gives the density functions f for the distributions used in the Process Capability platform. It also gives expected values and variances for all but the Johnson and SHASH distributions.
Normal
Equation shown here, Equation shown here, Equation shown here, Equation shown here
E(X) = μ
Var(X) = σ2
Beta
E(X) = Equation shown here
Var(X) = Equation shown here
where B(·) is the Beta function.
Exponential
E(X) = σ
Var(X) = σ2
Gamma
E(X) = ασ
Var(X) = ασ2
where Γ(·) is the gamma function.
Johnson
Johnson Su
Johnson Sb
Johnson Sl
where φ(·) is the standard normal probability density function.
Lognormal
E(X) =Equation shown here
Var(X) =Equation shown here
Mixture of Normals
The Mixture of 2 Normals and Mixture of 3 Normals options for Distribution share the following parameterization:
Equation shown here
where μi, σi, and πi are the respective mean, standard deviation, and proportion for the ith group, and φ(·) is the standard normal probability density function. For the Mixture of 2 Normals, k is equal to 2. For the Mixture of 3 Normals distribution, k is equal to 3. A separate mean, standard deviation, and proportion of the whole is estimated for each group in the mixture.
SHASH
Equation shown here, Equation shown here, 0 < δ, 0 < σ
where
φ(·) is the standard normal pdf
Equation shown here
Note: When γ = 0 and δ = 1, the SHASH distribution is equivalent to the normal distribution with location θ and scale σ.
Weibull
