Publication date: 02/06/2025
Save the Diagram as a Script
Saving the Cause and Effect Diagram as a script is a good approach if you have other processes that need to update the data table. The saved script contains all the commands needed to add and customize each area of the diagram.
To save the diagram as a script, perform the following steps:
1. Click the Cause and Effect Diagram red triangle and select Save Script > To Script Window.
2. Save the new script.
