Reliability and Survival Methods > Reliability Block Diagram
Publication date: 02/06/2025
Image shown hereReliability Block Diagram
Engineer System Reliabilities
The Reliability Block Diagram platform is available only in JMP Pro.
The Reliability Block Diagram platform shows the reliability relationships among a system's components. A reliability block diagram, also known as a dependence diagram, illustrates how component reliability contributes to the success or failure of a system. If reliability distributions are assigned to the components, the platform analytically models the reliability behavior.
Figure 12.1 Example of a Reliability Block DiagramĀ
Contents
Overview of the Reliability Block Diagram Platform
Example Using the Reliability Block Diagram Platform
The Reliability Block Diagram Window
Preview Window
Reliability Block Diagram Platform Options
Workspace Options
Configuration Settings
Distribution Configurations
Specify a Nonparametric Distribution
Options for Design and Library Items
Profilers
Component Importance and Time to Failure
Component Plots
Print Algebraic Reliability Formula
Generate Algebraic Expression Data Table
Clone and Delete
