Publication date: 02/06/2025
Image shown hereClone and Delete
In the Reliability Block Diagram platform, each system diagram that is listed in the Designs and the Library panels has options that aid in managing the design and library items. This section describes the Clone and Delete operations.
Image shown hereClone a Design or Library Item
The Clone option creates a new system design or library sub-system identical to the selected system design or library sub-system.
Select the Clone option from the red triangle menu for the design or library item to be copied.
A new design or library item is added to the Designs or Library list.
Save the file.
Image shown hereDelete a Design or Library Item
The Delete option removes the selected system design or a library sub-system from the panel.
Select the Delete option from the red triangle menu for the design or library item to be deleted.
The specified design or library item is deleted from the Designs or Library list.
Save the file.
