Publication date: 02/06/2025
Process Selection
In the Process Capability launch window, select the process variables to include in the analysis.
Y, Process
Assigns the variables that you want to analyze.
Notes:
The Transform menu is not available for the Select Column list in the Process Capability launch window. Right-click a column heading in the data table and select New Formula Column to create a transform column for use in Process Capability. See “Make a New Formula Column” in Using JMP for more information about creating new formula columns.
Reference columns for virtually joined tables are not available in the Process Capability platform.
