Quality and Process Methods > Variability Gauge Charts > Overview of Variability Charts
Publication date: 02/06/2025
Just as a control chart shows variation across time in a process, a variability chart shows the same type of variation across categories such as parts, operators, repetitions, and instruments. A variability chart plots the data and means for each level of grouping factors, with all plots side by side. Along with the data, you can view the mean, range, and standard deviation of the data in each category, seeing how they change across the categories. The report options are based on the assumption that the primary interest is how the mean and variance change across the categories.
Variability charts are commonly used for measurement systems analysis such as Gauge R&R. This analysis examines how much of the variability is due to operator variation (reproducibility) and measurement variation (repeatability). Gauge R&R is available for many combinations of crossed and nested models, regardless of whether the model is balanced.
Tip: The traditional name for a variability chart is a multi-vari chart, but because that name is not well known, the more generic term variability chart is used instead.
