Multivariate Methods > Normal Mixtures
Publication date: 02/06/2025
Normal Mixtures
Group Observations Using Probabilities
Normal mixtures is an iterative technique based on the assumption that the joint probability distribution of the observations is approximated using a mixture of multivariate normal distributions. These mixtures represent different clusters. The individual clusters have multivariate normal distributions.
When clusters are well separated, hierarchical and k-means clustering work well. But when clusters overlap, normal mixtures provides a better alternative, because it is based on cluster membership probabilities, rather than arbitrary cluster assignments based on borders.
Use Normal Mixtures for clustering when your data come from overlapping normal distributions. You need to specify the number of clusters in advance.
Figure 15.1 Normal Mixtures BiplotĀ
Contents
Overview of the Normal Mixtures Platform
Overview of Platforms for Clustering Observations
Example of Normal Mixtures Clustering
Launch the Normal Mixtures Platform
Normal Mixtures Report
Normal Mixtures Options
Individual Normal Mixtures Report
Cluster Comparison Report
Normal Mixtures NCluster Reports
Statistical Details for the Normal Mixtures Platform
