Publication date: 02/06/2025
Cluster Comparison Report
In the Normal Mixtures platform, the Cluster Comparison report gives fit statistics to compare the various models. The fit statistics are BIC and AICc. Smaller values of each indicate better fit. The best fit is indicated in a column called Best.
