Starting at JMP 18, the JMP help menu has been updated.
Menu Item |
Description |
Search JMP |
Enables you to search JMP for statistical tests and other capabilities. For more information, see Search JMP. |
JMP Online Help |
Enables you to open the latest version of the Help in a web browser. |
Help Tool |
Enables you to click on any part of a data table or report window to get help. |
Quick Start |
Formerly referred to as Tip of the Day, the Quick Start provides you with tips to help you quickly learn the basics of JMP. For more information, see Learn JMP Tips and Tricks. |
Documentation PDFs |
When installed, it provides local access to the JMP documentation PDF files. For more information, see Documentation PDF Add-in. Note: This menu option appears only if the documentation add-in is downloaded and installed. |
JMP Capabilities |
Opens a web browser that lists the tools and features that are available in JMP. It also provides links to the online Help, where more information is available. |
Learn JMP |
Opens a web browser that takes you to JMP learning materials. You can learn JMP through short videos and other resources. |
JMP User Community |
Opens a web browser where you can connect with other JMP users to learn more, solve problems, and share ideas for improving JMP. For more information, see JMP User Community. |
New in JMP |
Opens a web browser where you can learn about the new features in the latest release of JMP. |
Sample Data Folder |
Enables you to access sample data to learn about JMP analyses. Open a sample data file and run a script to see a sample analysis. For more information, see Sample Data Tables. |
Sample Index |
Enables you to find sample data tables based on analysis type or industry, teaching resources, and links to additional sample material. For more information, see Sample Data Tables. |
Scripting Index |
Enables you to search for JMP scripting commands and learn how to use them. For more information, see Learn about JSL. |
My JMP |
Opens my.jmp.com on the web. |
About JMP |
Displays your JMP version and enables you to check for software updates. This option is available only on Windows. |
