You can learn tips and tricks to help make using JMP easier. The Quick Start and Working Smarter in JMP are two tools that can help.
When you first start JMP, you see the Quick Start window. This window provides tips for using JMP. To turn off the Quick Start, clear the Show the Quick Start at startup check box. To view it again, select Help > Quick Start. Or, you can turn it off using the Preferences window.
You can also access the Working Smarter in JMP for tips. These tips provide an overview of several useful shortcuts in JMP. To view, go to https://community.jmp.com.
