Using JMP > Import Your Data > Import Data from a PI Server > Import Plot Data from a PI Server
Publication date: 02/06/2025
Plot data is optimized for graphing the results. The following field is specific to plot data:
No. of intervals
Specify the number of intervals to fetch. You can have up to five values per interval. This value indicates how much data will be imported.
Timeout
Specifies how long the server will wait for client communication. The default setting is 60 seconds.
Click Import to start importing plot data from the PI Server.
