Using JMP > Import Your Data > Import Data from a PI Server
Publication date: 02/06/2025
This import functionality is built on the Web API, and requires the following.
The PI Web Server to be deployed and running.
The PI Asset Framework must be installed and configured.
The PI Web Server OSIsoft Message Format (OMF) protocol must be enabled.
The PI Web Server’s search feature must be enabled.
PI Server data is typically machine generated and collected at defined intervals. The interval time can be short, leading to large amounts of data. For example, you have a process that is being monitored. Every 15 minutes, data is collected from various sensors and this data is sent to the PI Server. In another application, sensor readings can be collected more frequently, for example, every millisecond. The table below illustrates how this can lead to a large amount of data.
Table 3.6 Example of Collected Data
Number of sensors
10
10
10
Data Collected Every Unit of Time
15
1
1
Units of Time
Minutes
Seconds
Milliseconds
Units of Time per Day
96
86,400
86,400,000
Data Points per Day
960
864,000
864,000,000
Data Points per Month
29,200
26,280,000
26,280,000,000
Data Points per Year
350,400
315,360,000
315,360,000,000
The PI Server can import the following types of data:
raw data
plot data
interpolated data
