Publication date: 07/24/2024
Explore Patterns Options
The control panel and Explore Patterns red triangle menu contain options for summary and pattern tables.
Most Duplicated Values
Shows or hides a table of the values that appear most frequently in the data. Shows up to ten numbers for each column.
Longest Runs
Shows or hides a table of the longest run of the same value. The table contains the following information:
Starting Row
The row number that corresponds to the start of the run.
Count
The length of the run.
Value
The value of the entries in the run.
Rarity
A measurement of how rare it would be for the run to occur by chance. A high rarity indicates that it is not likely that the run occurred by chance. See Rarity in Longest Runs.
Longest Duplicated Sequences
Shows or hides a table of the longest sequence of values that appears more than once in the same column. Sequences of repeated values are also considered. If a sequence is duplicated more than once, each instance appears in the table. The table contains the following information:
Starting Row I
The row number that corresponds to the start of the first sequence.
Starting Row J
The row number that corresponds to the start of the duplicate sequence.
Count
The length of the sequence.
Rarity
A measurement of how rare it would be for the duplicate sequence to occur by chance. A high rarity indicates that it is not likely that the duplicate sequence occurred by chance. See Rarity in Longest Sequences.
First few values
The first few values of the duplicate sequence. Shows up to three values for each sequence.
Formatted Widths
Shows or hides a table of overall widths and decimal widths of the formatted values. The table contains the following information:
Width
The width size.
Overall Count
The number of observations in the column whose overall width equals the specified width.
Decimal Count
The number of observations in the column whose decimal width equals the specified width.
Fraction Length
Shows or hides a table of the continued fraction lengths for the values. A continued fraction is a representation of a number as a sequence of continually divided terms. The fraction length can indicate how rational a number is. Lengths of 15 or more indicate that the number is an irrational number, such as from a root function, a function involving an irrational number, or from a random number generator (Benford, 1938).
Note: In Explore Patterns, the maximum fraction length is 15. Numbers with fraction lengths of 15 or more are all reported as 15.
Length
The length of the continued fraction.
Count
The number of observations in the column whose continued fraction length equals the specified continued fraction length.
Leading and Trailing Digits
Shows or hides a table of counts for each leading and trailing digit, 1 through 9. For the leading digits, there are also columns for the expected rate and the minimum and maximum values that contain the corresponding leading digit. The expected rate is based on Benford’s Law, which states that the frequency that a number has a first digit that is equal to a is Fa = log10(a+1/a). This law applies to data that have a large range of numbers that all have four or more digits.
Spec Limit Matches
(Available when at least one of the columns has a Spec Limit column property.) Shows or hides a table of values that are exactly the lower specification limit, upper specification limit, or target value. If there are no exact matches, the report is not shown.
Distribution wrt Spec Limits
(Available only when at least one of the columns has a Spec Limit column property.) Shows or hides a table of observed versus expected observations that are outside of the specification limits. The Chi-Square and PValue columns appear only if the number of observed observations is significantly higher than the number of expected observations.
Duplicates Across Columns
Shows or hides the Duplicates Across Columns report. The report contains a table of sequences of values that appear in the same rows across more than one column. There is a note at the top of the report that states the minimum length of a sequence for it to be considered a duplicate. This number is specified in the launch window or control panel as Minimum Cross Column Duplicate Run Size. There is also a Colorize option at the top of the report. See Colorize Duplicates Across Columns.
(Available only after Duplicates Across Columns has been selected.) Colors cells in the data table to correspond to the duplicate matches found in the Duplicates Across Columns report. The rows that contain the duplicates are also selected.
Linear Relationships
Shows or hides the Linear relationships between variables report. The report contains a table of exact linear relationships across columns over a specified number of sequential rows. An exact linear relationship is defined as a linear relationship that has an R2 value greater than or equal to 0.999999. There is a note at the top of the report that states the minimum number of rows considered. This number is specified in the launch window or control panel as Minimum Rows for Linear Relationships. There is also a Colorize option at the top of the report. See Colorize Linear Relationships.
(Available only after Linear Relationships has been selected.) Colors cells in the data table to correspond to the linear relationships found in the Linear relationships between variables table. The rows that contain the linear relationships are also selected.
Save Columns
Contains the following save options:
Save Table of Runs
Saves the longest runs for all columns to a new data table. The data table contains the same columns as the Longest Runs table in the Univariate Patterns report and is sorted by Starting Row.
Save Table of Duplicate Sequences
Saves the longest duplicate sequences for all columns to a new data table. The data table contains the same columns as the Longest Duplicate Sequences table in the Univariate Patterns report and is sorted by Starting Row I.
Save Duplicates Across Columns
Saves the Duplicates Across Columns table to a new data table.
Save Linear Relationships
Saves the Linear relationships between variables table to a new data table.
Ordering Columns
Contains options for ordering. When you change the ordering, the column list in the Univariate Patterns report is reordered. The top column is automatically selected and the report for only that column is displayed.
Order by Runs Rarity
Orders the column list by the rarity values of the longest runs. Higher rarity values are at the top.
Order by Sequence Rarity
Orders the column list by the rarity values of the longest duplicate sequences. Higher rarity values are at the top.
Order by Column Name
Orders the column list in alphabetical order by column name.
Original Order
Orders the column list in the original order in which the columns were specified in the launch window.
Clear Cell Colors
Clears the cell colors for columns selected in the data table or for all columns if no columns are selected in the data table.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
