Basic Analysis > Oneway Analysis > Additional Examples of the Oneway Platform > Example of the All Pairs, Tukey HSD Test
Publication date: 02/06/2025
This example uses the Oneway platform to illustrate the Tukey HSD test.
4. Select age and click X, Factor.
5. Click OK.
6. Click the Oneway Analysis red triangle menu and select Compare Means > All Pairs, Tukey HSD.
Figure 6.15 All Pairs, Tukey HSD Comparison Circles
Figure 6.16 Means Comparisons Report for All Pairs, Tukey HSD
In Figure 6.16, the Tukey-Kramer HSD Threshold matrix shows the actual absolute difference in the means minus the HSD. Pairs with a positive value are statistically significantly different at the specified alpha significance level. The q* value in the confidence quantile table represents the quantile that is used to scale the HSDs. It has a computational role comparable to the quantile in a Student’s t test.
