Quality and Process Methods > Variability Gauge Charts > Example of a Variability Chart
Publication date: 07/24/2024
In this example, you want to identify the variation between three operators that each took three measurements of ten parts.
1. Select Help > Sample Data Folder and open Variability Data/2 Factors Crossed.jmp.
2. Select Analyze > Quality and Process > Variability / Attribute Gauge Chart.
3. For Chart Type, select Variability.
4. Select Measurement and click Y, Response.
5. Select Operator and click X, Grouping.
6. Select part# and click Part, Sample ID.
7. Click OK.
8. Click the Variability Gauge Analysis for Measurement red triangle and select Show Group Means and Connect Cell Means.
Figure 6.2 Example of a Variability Chart
Looking at the Std Dev chart, you can see that Cindy and George have more variation in their measurements than Tom, who appears to be measuring parts the most consistently. George seems to have the most variation in his measurements, so he might be measuring parts the most inconsistently.
