Publication date: 02/06/2025
Design
The Design section for a definitive screening design shows the runs for the definitive screening design. The runs are given in a standard order. To change the run order for your design table, you can select Run Order options in the Output Options panel before generating the table.
Note: Definitive screening designs for four or fewer factors are based on a five-factor design. See Definitive Screening Designs for Four or Fewer Factors.
