Design of Experiments Guide > Definitive Screening Designs
Publication date: 02/06/2025
Definitive screening designs (DSD) are screening designs. They are appropriate for early stage experimentation work, typically with four or more factors. DSD can be used for combinations of continuous or two-level categorical factors. They work best when most of the factors are continuous. Each continuous factor has three levels allowing one to investigate quadratic model terms for continuous factors.
Here are areas where definitive screening designs are superior to standard screening designs:
They help identify the causes of nonlinear effects by fielding each continuous factor at three levels. In standard screening designs, continuous factors have only two levels. You can add center points to screening designs, but these points establish only if curvature exists. They do not allow you to identify the factors responsible for quadratic effects.
They avoid confounding between any effects up through the second order. For continuous factors, definitive screening designs have main effects that are orthogonal to each other and orthogonal to two-factor interactions and quadratic effects. Two-factor interactions are not completely confounded with each other. Confounding occurs in many standard screening designs with a similar number of runs.
They avoid the need for costly additional experimentation to resolve ambiguity from the initial results of standard screening designs.
Figure 8.1 Plot of Response against Factor Values Showing Curvature
Contents
Overview of Definitive Screening Designs
Example of a Definitive Screening Design
Build A Definitive Screening Design
Responses
Factors
Design Options
Design
Design Evaluation
Output Options
Definitive Screening Design Options
Simulate Responses
Additional Examples of Definitive Screening Designs
Example of a Definitive Screening Design Compared to a Fractional Factorial Design
Example of a Definitive Screening Design with Blocking
Example of a Definitive Screening Design Compared with a Plackett-Burman Design
Statistical Details for Definitive Screening Designs
Structure of Definitive Screening Designs
Analysis of Experimental Data
