Publication date: 02/06/2025
Constant Stress ALT Options
The red triangle menu for the Plan Specifications includes the following option:
Remove
Removes the entire plan settings tab.
The red triangle menu for the Plan Comparisons includes the following options:
Remove
Removes the entire test plan tab.
Set Alpha Value
Enables you to change the alpha level that is used for the confidence limits in the Distribution Profiler and the R Precision Factor profiler.
Set Minimum Proportion
Enables you to set the minimum proportion of units that are assigned to the middle level of the compromise plan.
Tip: To save your constant stress ALT test plans, use File > Save As to save as a *.jmpdoe file
