Design of Experiments Guide > Constant Stress Accelerated Life Test Designs
Publication date: 02/06/2025
Designs for Accelerated Tests
Use the Constant Stress ALT platform to create a constant stress accelerated life test (CSALT) design. A CSALT test plan is useful when product reliability at normal use conditions is high. The Constant Stress ALT platform enables you to design accelerated life tests with up to three accelerating factors and to easily explore trade-offs among multiple plans and assumptions. Use an accelerated life test plan to define a testing strategy to test the product under constant stress conditions that are more severe than normal use conditions to accelerate the time until failures occur. Use this accelerated failure data to predict product reliability at normal use conditions.
Figure 22.1 Accelerated ModelsĀ
Accelerated Models
Contents
Overview of Constant Stress ALT Designs
Example of Constant Stress ALT Designs
Build a Constant Stress ALT Design
Constant Stress ALT Factors
Constant Stress ALT Plan Specifications
Constant Stress ALT Test Plans
Constant Stress ALT Options
Statistical Details for the Constant Stress ALT Design Platform
Failure Distributions for ALT Designs
R Precision Factor (for a 95% CI)
Optimality Criterion for Accelerated Life Tests
Multi-factor Designs
Balanced Plan Limitations
