Publication date: 02/06/2025
Competing Cause Workflow
Follow these steps to facilitate your use of the Competing Cause report:
1. For convenience, click the Competing Cause red triangle and select the Tabbed Report option.
2. Select the Individual Causes tab. For each failure cause, use the options in its individual Life Distribution outline to select a distributional fit. See Individual Causes.
3. Select the Cause Combination tab. For each failure cause, specify the desired distribution in each Distribution list. See Cause Combination.
4. Click Update Model.
5. Select the Statistics tab to explore and save results for the model. See Statistics for Competing Cause.
Note: Customizations made to the competing cause model report in the Statistics outline might be lost if you change the model and click Update Model again.
