Publication date: 02/06/2025
Competing Cause Report
In the Life Distribution platform, the Competing Cause report enables you to analyze competing causes to determine which causes are influential.
The Competing Cause report appears if you have assigned a Failure Cause column in the launch window. For an example of this report, see Example of Omitting Competing Causes. For technical details, see Statistical Details for Competing Causes.
The Competing Cause report contains the following content and options:
Competing Cause Workflow
Competing Cause Model
Cause Combination
Statistics for Competing Cause
Individual Causes
Competing Cause Report Options
Tip: If you find that the report window is too long, select Tabbed Report from the Competing Cause red triangle menu.
