Publication date: 02/06/2025
Cause and Effect Diagram Menu Options
The Cause and Effect Diagram red triangle menu contains options to redo the analysis and save scripts.
See “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Redo
Platform Preferences
Save Script
Save By-Group Script
