Scripting Guide > Three-Dimensional Scenes > Use the Matrix Stack
Publication date: 02/06/2025
JMP 3-D scenes use a matrix stack to keep track of the current transform. The stack is initialized to the identity matrix. Each time a translate, rotate, or scale message is given, the top matrix on the stack is changed.
Note: Unlike many OpenGL implementations, JMP does not use a transposed matrix.
The JSL example below uses Push Matrix and Pop Matrix to position pieces of the toy top and then return to the origin. This is faster than using the Translate message a second time in reverse.
Figure 13.15 Drawing With a Matrix StackĀ
toyTop = Scene Display List();
toyTop << Push Matrix;
toyTop << Translate( 0, 0, .1 );
toyTop << Color( 1, 0, 0 ); // red
// baseRadius, topRadius, height, slices, stacks
toyTop << Cylinder( 1, .2, .2, 25, 5 );
toyTop << Pop Matrix;
toyTop << Translate( 0, 0, -.1 );
toyTop << Rotate( 180, 1, 0, 0 );
toyTop << Color( 0, 1, 0 ); // green
toyTop << Color( 0, 0, 1 ); // blue
toyTop << Sphere( .5, 30, 30 ); // radius, slices, stacks
toyTop << Color( 1, 1, 0 ); // yellow
// innerRadius, outerRadius, slices, rings, startAngle, sweepAngle
toyTop << Partial Disk( 1, 1.2, 25, 2, 0, 270 );
toyTop << Color( 1, 0, 1 ); // magenta
toyTop << Cylinder( 1, 1, .2, 25, 3 );
toyTop << Rotate( 90, 1, 0, 0 );
toyTop << Translate( 0, .5, 0 );
toyTop << Color( 0, 1, 1 ); // cyan
toyTop << Text( "center", "baseline", .2, "Toy Top" );
scene = Scene Box( 600, 600 ); // make a scene box...holds an OpenGL scene
New Window( "Example 3", scene ); // put the scene in a window
scene << Perspective( 45, 3, 7 );
scene << Translate( 0.0, 0.0, -4.5 );
scene << Rotate( -85, 1, 0, 0 );
scene << Rotate( 65, 0, 0, 1 );
scene << Call List( toyTop );
scene << Update; // update the display box
There are some cases where you want to replace the current matrix on the stack. For these cases, use the Load Matrix function.
Load Matrix(m)
where m is a 4x4 JMP matrix that is loaded onto the current matrix stack.
The Mult Matrix function is similar.
Mult Matrix(m)
When the Mult Matrix function is issued, the matrix on the top of the current matrix stack is multiplied by m.
The following matrices perform some simple commands.
Translation:
 [1  0  0  x
 0  1  0  y
 0  0  1  z
 0  0  0  1]
In the following rotation matrices, c = cos(angle) and s=sin(angle).
Rotation about X axis:
 [1  0  0  0
 0  c -s  0
 0 -s  c  0
 0  0  0  1]
Rotation about Y axis:
 [c  0  s  0
 0  1  0  0
-s  0  c  0
 0  0  0  1]
Rotation about Z axis:
 [c -s  0  0
 s  c  0  0
 0  0  1  0
 0  0  0  1]
For example, here are two equivalent (except for the translation being opposite) ways to translate and rotate a display list.
// first way uses matrix
gl << Push Matrix;
xt = Identity( 4 ); // translate this one left by .75
xt[1, 4] = -.75;
xr = Identity( 4 ); // rotate this one, cos needs radians, not degrees
xr[2, 2] = Cos( 3.14159 * a / 180 );
xr[2, 3] = -Sin( 3.14159 * a / 180 );
xr[3, 2] = Sin( 3.14159 * a / 180 );
xr[3, 3] = Cos( 3.14159 * a / 180 );
yr = Identity( 4 );
yr[1, 1] = Cos( 3.14159 * a / 180 );
yr[1, 3] = Sin( 3.14159 * a / 180 );
yr[3, 1] = -Sin( 3.14159 * a / 180 );
yr[3, 3] = Cos( 3.14159 * a / 180 );
zr = Identity( 4 );
zr[1, 1] = Cos( 3.14159 * a / 180 );
zr[1, 2] = -Sin( 3.14159 * a / 180 );
zr[2, 1] = Sin( 3.14159 * a / 180 );
zr[2, 2] = Cos( 3.14159 * a / 180 );
// order of multiplication matters with matrices
gl << Mult Matrix( xt * xr * yr * zr );
gl << Arcball( dl, 1 );
gl << Pop Matrix;
// second way uses functions
gl << Push Matrix;
gl << Translate( .75, 0, 0 ); // translate this one right by .75
gl << Rotate( a, 1, 0, 0 ); // rotate this one in degrees
gl << Rotate( a, 0, 1, 0 ); // order of operations also matters here
gl << Rotate( a, 0, 0, 1 );
gl << Pop Matrix;
It is not possible to read back the current transform matrix, because the matrix exists only while the display list is drawing, not while your JSL script is creating it. If you must know its content, create it in JSL and use Load Matrix to put it on the stack.
