Publication date: 02/06/2025
Time Series Basic Diagnostics Chart
The information that is shown in the Time Series Basic Diagnostics chart depends on the Time Series Report red triangle menu options. The red triangle menu options that show or hide information from the diagnostics chart are Autocorrelation, Partial Autocorrelation, Variogram, and AR Coefficients. By default, Autocorrelation and Partial Autocorrelation are shown.
Autocorrelation Chart
The Autocorrelation option shows or hides the following columns in the Time Series Basic Diagnostics chart:
Lag
The number of periods between points.
Note: The number of lags begins with 0 as the default. To compute correlations beginning with lag 1, modify the JMP preferences before generating the graph. Select File > Preferences > Platforms > Time Series, and then select Suppress Lag 0 in ACF and PACF.
AutoCorr
The autocorrelation for the kth lag, which is computed as follows:
Equation shown here where Equation shown here
and Equation shown here is the mean of the N non-missing points in the time series. By definition, the first autocorrelation (lag 0) always has length 1.
The bars graphically depict the autocorrelations. The blue curves represent twice the large-lag standard error (± 2 standard errors), which is computed as follows:
Equation shown here
Ljung-Box Q
Used to test whether a group of autocorrelations is significantly different from zero, or to test that the residuals from a model can be distinguished from white noise. Q is the test statistic.
p-Value
The p-value from the Ljung-Box test.
Partial Autocorrelation Chart
The Partial Autocorrelation option shows or hides the following columns in the Time Series Basic Diagnostics chart:
Lag
Partial
The partial autocorrelation for the kth lag.
The bars graphically depict the partial autocorrelations. The blue lines represent ± 2 standard errors for approximate 95% prediction limits, where the standard error is computed as follows:
Equation shown here for all k
Variogram Chart
The Variogram option shows or hides the following columns in the Time Series Basic Diagnostics chart:
Lag
Variogram
The variogram measures the variance of the differences of points k lags apart and compares it to that for points one lag apart. The variogram is computed from the autocorrelations as follows:
Equation shown here
where rk is the autocorrelation at lag k.
AR Coefficients Chart
The AR Coefficients option shows or hides the following columns in the Time Series Basic Diagnostics chart:
Lag
AR Coef
The coefficients approximate those that you would obtain from fitting a high-order, purely autoregressive model.
