Multivariate Methods > Cluster Variables > The Variable Clustering Report
Publication date: 02/06/2025
By default, the Variable Clustering report in the Cluster Variables platform contains the following sections:
Color Map on Correlations
Cluster Summary
Cluster Members
Standardized Components
Tip: When you select rows in any of the Variable Clustering tables, the corresponding columns in the data table are also selected. Press Ctrl and click the row to deselect the column in the data table.
