Predictive and Specialized Modeling > Response Screening > The Response Screening Report
Publication date: 02/06/2025
The Response Screening report consists of a section of plots and a section of reports.
Response Screening Plots
Response Screening Report Tables
Tip: To change the layout of the plot section or the report section, right-click the top of the desired section and select Set Style. The default layout is a tabbed report for up to five plots. When there are more than five plots the default is a combo layout. The combo layout uses a drop down plot selector.
