Multivariate Methods > Hierarchical Cluster > The Hierarchical Clustering Report
Publication date: 02/06/2025
The Hierarchical Clustering report displays the method used, a dendrogram, and the Clustering History table. If you assigned a column as a Label in the launch window, the column’s values identify each observation in the dendrogram.
Dendrogram
Clustering History
