Design of Experiments Guide > The Fit Two Level Screening Platform
Publication date: 02/06/2025
Analyze Data from Screening Experiments
The Fit Two Level Screening platform is a modeling platform that you can use to analyze experimental data results from a screening design. The Fit Two Level Screening platform helps you identify effects that have a large impact on the response.
The Fit Two Level Screening platform is based on the principle of effect sparsity (Box and Meyer 1986). This principle asserts that relatively few of the effects that you study in a screening design are active. Most are inactive, meaning that their true effects are negligible and that their estimates can be treated as random error.
A screening design often provides no degrees of freedom for error when the model of interest includes interaction terms. Consequently, classical tests for effects are not available. In such cases, the Fit Two Level Screening platform is particularly useful.
Figure 11.1 Half Normal Plot from Fit Two Level Screening Report
Contents
Overview of the Fit Two Level Screening Platform
Example of the Fit Two Level Screening Platform
Launch the Fit Two Level Screening Platform
The Fit Two Level Screening Report
Contrasts
Half Normal Plot
Make or Run Model
Additional Examples of the Fit Two Level Screening Platform
Example of a Plackett-Burman Design Analysis
Example of Effect Heredity
Example of a Supersaturated Design Analysis
Statistical Details for the Fit Two Level Screening Platform
Statistical Details for Order of Effect Entry
Statistical Details for Fit Two Level Screening as an Orthogonal Rotation
Statistical Details for Lenth’s Pseudo-Standard Error
Statistical Details for Lenth t-Ratios
