Basic Analysis > Tabulate
Publication date: 07/24/2024
Tabulate
Create Summary Tables Interactively
Use the Tabulate platform to interactively construct summary tables, or pivot tables, of descriptive statistics. The Tabulate platform is an easy and flexible way to present summary data in tabular form. Tables are built from assigning data table columns as rows or columns in the tabulation and then assigning the desired summary statistics.
Figure 9.1 Tabulate Examples
Tabulate Examples
Contents
Example of the Tabulate Platform
Launch the Tabulate Platform
Tabulate Platform Dialog Window
Add Statistics
Tabulate Platform Report
Analysis Columns
Grouping Columns
Column and Row Tables
Edit Tables
Tabulate Platform Options
Show Test Build Panel
Pop-up Menu for Columns
Additional Examples of the Tabulate Platform
Example of Creating Different Tables and Rearranging Contents
Example of Combining Columns into a Single Table
Example Using a Page Column
Example of Stacking Grouping Columns
Example Using a Unique ID Column
Example of Packing Columns
