Publication date: 02/06/2025
Supercategories Options
The following options are available in the Supercategories red triangle menu in the Column Properties window:
Hide
Hides categories within a supercategory in the crosstab table and frequency chart.
Tip: If you want the flexibility to show or hide the individual categories in your reports, do not use the Hide option. Use the Response Level option in the Categorical red triangle menu.
Net
(Available only for a multiple response column.) Prevents individual respondents from being counted twice when they appear in more than one supercategory.
Add Mean
Includes mean statistics in the report.
Add Std Dev
Includes standard deviation statistics in the report.
Add All
Includes total responses in the report. By default, the Total Responses column is always included.
Note: Supercategories are supported for all response effects except Repeated Measures and Rater Agreement.
