Fitting Linear Models > Stepwise Regression Models
Publication date: 02/06/2025
Find a Model Using Variable Selection
The Stepwise personality of the Fit Model platform enables you to fit stepwise regression models, explore all possible models for a set of regressors, and conduct model averaging.
Stepwise regression is an approach to selecting a subset of effects for a regression model. It can be useful in the following situations:
There is little theory to guide the selection of terms for a model.
You want to interactively explore which predictors seem to provide a good fit.
You want to improve a model’s prediction performance by reducing the variance caused by estimating unnecessary terms.
For categorical predictors, you can do the following:
Choose from among various rules to determine how associated terms enter the model.
Enforce effect heredity.
Contents
Overview of Stepwise Regression
Example Using Stepwise Regression
The Stepwise Report
Stepwise Platform Options
Stepwise Regression Control Panel
Current Estimates Report
Step History Report
Models with Crossed, Interaction, or Polynomial Terms
Models with Nominal and Ordinal Effects
Construction of Hierarchical Terms
Perform Binary and Ordinal Logistic Stepwise Regression
The All Possible Models Option
The Model Averaging Option
Validation Options in Stepwise Regression
Validation Set with Two or Three Values in Stepwise Regression
K-Fold Cross Validation in Stepwise Regression
Additional Examples of the Stepwise Personality
Example of the Combine Rule
Example of a Model with a Nominal Term
Example of the Restrict Rule for Hierarchical Terms
Example of Logistic Stepwise Regression
Example of the All Possible Models Option
Example of the Model Averaging Option
