Discovering JMP > Introducing JMP > Understand the JMP Workflow > Step 3: Request Additional JMP Output
Publication date: 02/06/2025
Continue to use the same report window that you created in Step 2: Remove the Box Plot from a JMP Report.
1. Click the red triangle next to Profits ($M) and select Test Mean.
The Test Mean window appears.
2. Enter 500 in the Specify Hypothesized Mean box.
3. Click OK.
The test for the mean is added to the report window.
Figure 2.8 Test for the MeanĀ
Test for the Mean
