Fitting Linear Models > Statistical Details
Publication date: 02/06/2025
Statistical Details
This appendix discusses the different types of response models, their factors, their design coding, and parameterization. It also includes many other details of methods described in the main text.
The JMP system fits linear models to three different types of response models that are labeled continuous, ordinal, and nominal. Many details about the factor side are the same for the different response models, but JMP supports graphics and marginal profiles only for continuous responses—not for ordinal and nominal.
Different computer programs use different design-matrix codings, and thus parameterizations, to fit effects and construct hypothesis tests. JMP uses a different coding than the GLM procedure in SAS, although in most cases JMP and SAS GLM procedure produce the same results. The following sections describe the details of JMP coding and highlight those cases when it differs from that of the SAS GLM procedure.
Contents
The Response Models
Continuous Responses
Nominal Responses
Ordinal Responses
The Factor Models
Continuous Factors
Nominal Factors
Ordinal Factors
Frequencies
The Usual Assumptions
Assumed Model
Relative Significance
Multiple Inferences
Validity Assessment
Alternative Methods
Key Statistical Concepts
Uncertainty, a Unifying Concept
The Two Basic Fitting Machines
Likelihood, AICc, and BIC
Power Calculations
Computations for the LSN
Computations for the LSV
Computations for the Power
Computations for the Adjusted Power
Inverse Prediction with Confidence Limits
