Publication date: 02/06/2025
Statistical Details for the Wide Linear Algorithm
Wide Linear discriminant analysis is performed as follows:
The data are standardized by subtracting group means and dividing by pooled standard deviations.
The singular value decomposition is used to obtain a principal component transformation matrix from the set of singular vectors.
The number of components retained represents a minimum of 0.9999 of the sum of the squared singular values.
A linear discriminant analysis is performed on the transformed data, where the data are not shifted by group means. This is a fast calculation because the pooled-within covariance matrix is diagonal.
