Basic Analysis > Oneway Analysis > Statistical Details for the Oneway Platform > Statistical Details for the Summary of Fit Report
Publication date: 02/06/2025
This section contains details for the Summary of Fit report in the Oneway platform.
Rsquare
Using quantities from the Analysis of Variance report for the model, the R2 for any continuous response fit is calculated as follows:
Equation shown here
Adj Rsquare
Adj Rsquare is a ratio of mean squares instead of sums of squares and is calculated as follows:
Equation shown here
The mean square for Error is found in the Analysis of Variance report and the mean square for C. Total can be computed as the C. Total Sum of Squares divided by its respective degrees of freedom. See Analysis of Variance.
