This section describes the summary of fit measures reported in the Structural Equation Models platform.
The AICc and BIC are defined as follows:
AICc =
BIC =
where:
-2logL is twice the negative log-likelihood.
n is the sample size.
k is the number of parameters.
For more information about the likelihood-based measures in the Model Comparisons report, see “Likelihood, AICc, and BIC” in Fitting Linear Models.
The BIC relative to the unrestricted model (BICu) is defined as follows:
BICu =
where:
is the chi-square statistic of the fitted model.
dfmin is the degrees of freedom of the fitted model.
The BICu for a fitted model is equivalent to the BIC for the fitted model minus the BIC for the unrestricted model. For more information about the BIC relative to the unrestricted model, see Bollen et al. (2014).
The comparative fit index (CFI) is defined as follows:
CFI =
where:
is the chi-square statistic of the independence model.
df0 is the degrees of freedom of the independence model.
For more information about the CFI, see Bentler (1990).
The relative noncentrality index (RNI) is defined as follows:
RNI =
where:
For more information about the RNI, see McDonald and Marsh (1990).
The Tucker-Lewis index (TLI) is defined as follows:
TLI =
where:
For more information, see West et al. (2012).
The Bentler-Bonett normed fit index (NFI) is defined as follows:
NFI =
where:
The revised goodness-of-fit index (Revised GFI) is defined as follows:
Revised GFI =
where:
p is number of observed variables in the fitted model.
The revised adjusted goodness-of-fit index (Revised AGFI) is defined as follows:
Revised AGFI =
where:
p* is the number of unique entries in the covariance matrix and the mean vector of the observed variables.
For more information, see Maiti and Mukherjee (1991) and West et al. (2012).
The root mean square error of approximation (RMSEA) is defined as follows:
RMSEA =
where:
The confidence limits for RMSEA are computed using the cumulative distribution function of the noncentral chi-square distribution Φ(x|λ, d). The 90% confidence limits are computed as follows:
Lower limit =
Upper limit =
where:
λL satisfies Φ(|λL, dfmin) = 0.95.
λU satisfies Φ(|λU, dfmin) = 0.05.
For more information, see Maydeu-Olivares et al. (2017).
The formulas for RMR and SRMR are defined as follows:
RMR =
SRMR =
where:
p is the number of manifest variables.
b is the number of unique entries in the covariance matrix and the mean vector of the observed variables:
sij is the (i, j)th element of the input covariance matrix.
is the (i, j)th element of the predicted covariance matrix.
is the ith element of the vector of sample means.
is the ith element of the vector predicted means.
For more information, see the CALIS Procedure chapter in SAS Institute Inc. (2023a).
