Publication date: 02/06/2025
Standardize Column Properties
To standardize properties across columns
1. Select the columns that you want to standardize. One of those columns must contain the property that you want to add to the other columns.
2. Select Cols > Standardize Attributes.
3. Select Column Properties in the Standardize Properties area.
4. Select the property that you want to standardize. Modify the property settings if necessary.
5. Click Apply to standardize the property across selected columns. Changes are shown in the data table, open reports, and open graphs.
Or click OK to standardize the property across selected columns and close the column properties window.
