Publication date: 07/24/2024
Specifying Two ID Variables
In the Bubble Plot launch window, specifying a second ID variable provides a hierarchy of categories. For example, you might specify countries as the first ID variable, resulting in a separate aggregated bubble for each country. A second ID variable, perhaps designating regions within each country, would further split each country when you select the Split button in the bubble plot.
