Publication date: 02/06/2025
Select Bubbles
In a JMP bubble plot, click a bubble to select it. Note the following:
Visually, selected bubbles become darker or brighter, and non-selected bubbles are more transparent.
If the bubble was not filled initially, selection fills it.
If no bubbles are selected, all of the bubbles are semi-transparent.
When you select a bubble, all of the rows in the data table that correspond to the selected bubble are highlighted. Note the following:
If the bubble is an aggregate based on an ID column, all of the rows for that ID are highlighted. Otherwise, the one row represented by that bubble is highlighted.
If you specify an ID and a Time variable, selecting a bubble highlights all of the rows for that ID, across all of the Time levels.
If you select a row from the data table, it is selected in the associated bubble plot. Note the following:
If you have not specified a Time variable, selecting one row from the data table highlights the corresponding bubble in the plot.
If you have specified a Time variable, selecting one row from the data table highlights the corresponding bubble for only that time period in the dynamic bubble plot.
