Using JMP > Save and Share Your Data > Save Data Tables > Save JMP Data as a JSON File
Publication date: 07/24/2024
You can save a data table as a JSON file, which consists of name and value pairs. JSON files are often used to exchange data between applications.
To save a data table as a JSON file, follow these steps:
Windows
1. Select File > Export.
2. Select JSON Data and click Next.
3. (Optional) Rename the file.
4. Click Save.
macOS
4. Click Export.
