Using JMP > Save and Share Your Data > Save Reports > Save a JMP Analysis as a Script
Publication date: 02/06/2025
After completing an analysis and receiving a report, you might want to save the process that you used to arrive at the report as a JSL script. You can save the script inside the data table, inside the report, or in a separate script window. To do this, click the red triangle in the report title and select the Save Script option that you prefer. See “Save Script Menus in JMP Reports”.
Non-English versions of JMP can save scripts in either English or your local language. See “General JMP Preferences”.
